M5526 image formation issue
  • Scottb
    • Apr 2013
    • 306
    I have included examples of the issue, but prints and internal prints are fine, scans off the glass give a deletion, and scans from the DP are extra festive in the same area as the glass deletion.
    all thats been done at the moment is reset connectors. and check that the scanner LEDs all light through out the scan process. Kyocera's site is down at the moment, so i cant use those help tools. has anyone else ran across this or similar on these little guys.
    This gallery has 3 photos.
  • ihatefinishers13
    Senior MFP Technician
    • Feb 2020
    • 700
    I've had almost this same issue. I don't have an example unfortunately, but I was told to replace the CCD and ribbon cable. The downside, you have to ALSO order a calibration chart (302NV94330 - double check that) that was $96 USD at the time. Haven't had to use it since. Our lines were black, but same thing - 302R794320 was the part number for reference. If you can call tech support, I would.
    • Ropariva
      • Mar 2016
      • 675
      Yep, looks like you have a failed CCD or cable.
      • Scottb
        • Apr 2013
        • 306
        Thanks for the help, I appreciate it.
