CS3051 color issue
  • McCrazy
    • Feb 2020
    • 15
    CS3051 color issue
    I've got a 3051ci misprinting at the top of pages. This machine has brand new developers/drums, and a new yellow laser scanner. When printing full page C/Y/M/K test pages they look great, but when doing normal prints it will fade out on the top, or have a yellow hue. If we make a copy of one of the full color test pages then it fades/gets light at the top across the page as well. I'm wondering if we could have a black laser scanner going bad or the high voltage power supply possible.... I have attached some examples, and also a color registration page as reference. All colors on the registration page and full color test pages print out just fine, but any other word/excel/pdf etc all have color misprint. Status pages and all internal print jobs/tables print perfect. Document_2021-07-20_150517.pdfDocument_2021-07-20_150451.pdfAny input is welcomed. I have also attached a copy of the original document as a guide to what this print job looks like compared to the original. Visitor Meeting Overview (3).pdf Thank you all!
    • 23009
    Re: CS3051 color issue
    Copies will never look as perfect as direct prints, due to resolution loss from the scanner, but that's pretty extreme. It sounds obvious, but have you thoroughly cleaned the scanner optics and CCD lens, before doing your color calibration?
    You've ruled out the laser, if the the direct prints look fine. =^..^=
    • PrintWhisperer
      • Feb 2018
      • 472
      The CAM release system on your DV's could be binding or popped out of their holders. It was a known issue for these models.
      (The top header should be process grey, but since it appears yellow it is missing the C and M halftone BTW)
      Check the long stainless rod on the back side and make sure it is notched into it's holders and moves freely when pushed in. It should move the DV roller away/toward drum with spring pressure on the release motion.
      "Being ignorant is not so much a shame, as being unwilling to learn" - Benjamin Franklin
      • Ropariva
        • 678
        • avio2
          • Jul 2010
          • 150
          pdf whit color registration are faded ,i think this is a scan problem and i think clean very well mirrors and ccd
