MA4000cifx Black bands
  • nathicana
    • Aug 2008
    • 335
    This is a new MA4000cifx with intermittent Black bars that are roughly the same size when they happen.
    It looked like a loss of main charge to me. I switched the black drum with the yellow drum to see if the problem changed, it didn't.
    I've only seen black bars, not colored even when doing full color prints. I don't think it has happened in full color mode though
    2754_001.pdf
    I called Kyocera and the suggestion was the high voltage unit 302YJ94130. I ordered one.
  • ihatefinishers13
    Senior MFP Technician
    • Feb 2020
    • 695
    Just curious, did you try and use a loupe to check and see what is making that black band? Yes, it looks black, but there could be other colors making it up. Very strange though!
      • 23008
      There is only K in the posted sample, but it might be a monochrome scan. =^..^=
      • Ropariva
        • 674
        • Dark Helmet
          • May 2009
          • 847
          That sure looks similar to the 7003 with a damaged drum and transfer belt.
          • nathicana
            • Aug 2008
            • 335
            Thanks for the replies.
            I replaced the High Voltage board, did not fix the problem.
            My co worker inspected the black areas and did not find any C, M, or Y colors.
            I hadn't considered the transfer belt but I'm open to anything.
            I appreciate any troubleshooting ideas
            • Dark Helmet
              • May 2009
              • 847
              On the 7003 you had to do the drum and belt as a pair. If you did just 1 the problem returned.
              • nathicana
                • Aug 2008
                • 335
                I called Kyocera and asked them to send us a replacement machine. They were nice enough to do that, it arrived today.
                If anyone finds the solution to this problem I'm interested. I didn't want to buy any more parts so I never tried a new(er) transfer belt and drums.
                • toddanderson
                  • Dec 2005
                  • 236
                  [ATTACH]n1572589[/ATTACH]
                  Has anyone else seen this black band ? I have a machine MA4000 doing the same thing, very random the black band shows up
