I have a 6052ci and I cant seem to find the part number for the drum /developer relay PWB It has the part listed as one to replace for error c7901 but they must call it something different in the parts book because I have searched and cant find it.
Part number needed for 6052ci
Tags: None
take care for U122 and U165, both parts are not connected to this pwb.
Have had several cases with C7901 and belt broke the serial data stream.
FYI
Stream starts on bk drum sn, if the belt break the serial stream, system get no response and C7901 is coming up.
Disassemble all LLU parts and assemble again step by step.
After each step check related service point.
U117 for dk, U984 for dv, U122 for belt and U165 for fk
One case i have had with C1950, after mounting from new belt i got C7901
Finally the new belt broke the stream. With other belt the error was gone.Comment
👍 1Comment
don't feel bad. i would say well over half of the copier brands are not consistent with the name from the service manual to the parts manual. it's a real pain in the back side.Comment
Yea what I don't understand is why they put the part name change in the front of the service manual or better yet don't change the part nameComment
