Part number needed for 6052ci
  • carolscurriculum
    • May 2017
    • 39
    I have a 6052ci and I cant seem to find the part number for the drum /developer relay PWB It has the part listed as one to replace for error c7901 but they must call it something different in the parts book because I have searched and cant find it.
  • yakyitz
    • 245
    302nd94070 parts pwb drum dlp connect assy sp
    • KYO_OEM
      • Aug 2011
      • 714
      take care for U122 and U165, both parts are not connected to this pwb.
      Have had several cases with C7901 and belt broke the serial data stream.
      FYI
      Stream starts on bk drum sn, if the belt break the serial stream, system get no response and C7901 is coming up.
      Disassemble all LLU parts and assemble again step by step.
      After each step check related service point.
      U117 for dk, U984 for dv, U122 for belt and U165 for fk
      One case i have had with C1950, after mounting from new belt i got C7901
      Finally the new belt broke the stream. With other belt the error was gone.
      • carolscurriculum
        • May 2017
        • 39
        Thanks for that I finally saw something about it in the front of the maint manual it makes no sense that they dont change the name everywhere
        • dalewb74
          • Feb 2018
          • 1153
          don't feel bad. i would say well over half of the copier brands are not consistent with the name from the service manual to the parts manual. it's a real pain in the back side.
          • carolscurriculum
            • May 2017
            • 39
            Yea what I don't understand is why they put the part name change in the front of the service manual or better yet don't change the part name
