Calibration marks issue 508ci
  • toddanderson
    • Dec 2005
    • 238
    On a 508ci
    I get these calibration marks on the page for the first few pages than it cleans off, than returns.
    I have replaced the transfer belt and the main voltage and I have check all the spring bias contacts
  • sparkycivic
    • Apr 2017
    • 348
    Re: Calibration marks issue 508ci
    Did the new transfer belt fix it for a while then return? or was the new belt ineffective at changing the behaviour? Can you be certain that the cleaning section of the belt is being driven? Try putting a mark on the gears, run the device, then look for the marks to see if they moved. have a look for signs of blockage in the waste passages for the belt as well...
      • 23010
      +1
      I'd suspect the waste auger system is obstructed. A new belt would be able to clean until it filled the primary transfer cleaner.
