Kyocera 3253ci False Jam 00
  • CopyTech03
    • Jul 2020
    • 55
    [Jamming] Kyocera 3253ci False Jam 00
    Has anyone ran into this issue where this machine will give a false jam 00 out of nowhere? For instance you could just finish running a print job, panel shows Ready To Copy, you open and close the right side cover and it indicates a J-00. Open and close the cover again and it will clear (sometimes will take a few times opening and closing to clear). Has latest firmware.
  • PrintWhisperer
    • Feb 2018
    • 473
    Re: Kyocera 3253ci False Jam 00
    When the machine shows your Jam 00 enter MM031 and see what PF sensor is active.
    "Being ignorant is not so much a shame, as being unwilling to learn" - Benjamin Franklin
      • 23010
      +1 on this. =^..^=
      • tmaged
        Owner/Service Manager
        • Oct 2008
        • 1897
        Clean the sensor above the transfer roller. IIRC, what it's listed as in MM031 and in the manual are called different names, so it's a bit confusing.
        Hope that helps !
        -Tony
        www.dtios.com
        Become a fan on Facebook
          • 23010
          I know what you mean: sometimes called Belt Jam, sometimes called Belt Wound Sensor, sometimes called Loop Sensor.
          That's the one that I've seen get dusty. =^..^=
          • JR2ALTA
            • Feb 2010
            • 2033
            One Kyocera flaw they need to fix if that you can't check LCC sensors, e.g. PF7100, PF7110
            • PrintWhisperer
              • Feb 2018
              • 473
              ...and the parts manual will have yet a third name. Always resolve the sensor name to the parts layout in Machine Design.
              JR2ALTA while this is true and would seem an oversight, an LCT sensor problem would only exhibit while using the LCT and is easily isolated. Plus there are operational testing modes for them so you can actually use some old-fashioned troubleshooting.
