Utax 3206ci producing backgound copies after replacing black drum
  • outdoorkatie123
    • Feb 2017
    • 50
    Hi wondering if anyone had the same issue
    Called to a utax 3206 this morning with routine maintenance A
    Replaced the black drum and reset count calibrated and tested copier
    the prints that came out had a really heavy back ground on the page
    tried three different drums and all had the same problem background on copies
    brought all three drums back to workshop and all working fine
    put the old drum back in and copies 100%
  • Lunatech
    • Oct 2012
    • 208
    If you didn't you should be sure to power the machine down and unplug it before removal and replacement. I usually won't go as far as unplugging but I always make sure the main power is off. On occasion I have had similar issues as you describe and shutting down, unplugging, replacing and power up does the trick. As I recall I had to put the old drum back in get it all calibrated then perform the afore mention procedure.
    For what it's worth I hope this helps.
    • KYO_OEM
      • Aug 2011
      • 719
      To be shure you can check U110 and U120 for correct counters.
      If only one of both counters wouldn`t set to "0" you can get this problem and additional new dk needed, because you are not able to change DK eeprom values.
      • outdoorkatie123
        • Feb 2017
        • 50
        Thanks guys the machine is working fine for now will call when in area and replace drum
        • Lunatech
          • Oct 2012
          • 208
          Sounds good. Let us know what happens. Safe travels.
