taskalfa 5002
  • Gab
    • Aug 2015
    • 671
    taskalfa 5002
    At an area at the botton side lihgt image. When i opened to check drum and developer i noticed that tha buton on dev unit was not pressed. I checked also drum unit and there was toner on the top of the drum. i cleaned .
    When i entered dev unit , buton did not stayed pressed and when i tried.some copies were blank So with an adhesive take i kept it pressed. Now image is darker and with background. Any idea?
  • Ropariva
    • 676
    Common issue with the early developer units. I just screw in a self tapping style screw down the side to hold it in.
    • ihatefinishers13
      Senior MFP Technician
      • Feb 2020
      • 707
      I've also just taped a thick piece of paper/cardboard in the inside of that maintenance door that drops down, and it will keep it pressed in. Customers are never going in that door, so any mod you do won't ever be seen. Cheap design, per usual Kyocera. Definition of UNDER-engineered products.
      • Ropariva
        • 676
        Never underestimate customers. We have had them open that door, remove the developers and pour the dev into the bin. We now place a sticker on that door at run up “Do not open. Service techs only”
        • Rpizzle
          • Mar 2014
          • 47
          I usually take the spring off the dv and slide the dk in at the same time. Have had screw and other methods fail on me. remove spring quick and easy, plus no sight of a rig job.
          • kuby
            • Oct 2007
            • 1408
            On the earlier machines that had waste toner bottles, we had the customer pour that toner back in the machine. Took me a couple of dev changes until I was going to empty the waste bottle and they said "Wait" we pour that back in the machine to save money buying toner. Got Ya.
