Fax install on a 406ci - Fax System 10 - Getting Error
  • kuby
    • Oct 2007
    • 1414
    Installing a fax system 10 in a 406ci and get a C0620, Check DIMM on the main PWB error. Does the fax need a memory card to work? There are DIMM in the YS1 (STD) and the YS3 (OPT) but I see nothing in the YS5. Thanks
  • Santander
    • May 2009
    • 768
    Re: Fax install on a 406ci - Fax System 10 - Getting Error
    There is a DIMM card that comes with the fax option that needs to be installed with the fax option. Just installing the fax board in the machine will not enable the fax as your error code indicates without the fax DIMM. If you switched the fax option from another machine go back to the original unit and remove the DIMM to install in the other unit. The installation guide shows the proper connector to plug the fax dimm into.
    • kuby
      • Oct 2007
      • 1414
      There was no DIMM with the fax card, just the fax card? Guess I will order one.
      Just what I thought.
      • Necrocannibal
        • May 2008
        • 212
        I am having the same issue, ordered a Fax System 10 which is supposed to be for the 406ci and getting the same error telling me to check DIMM on main board. No DIMM was in the box, did that fix your issue? If so do you by chance have the part number for it?
        Thanks!
        EDIT*
        Is the part number for it? There are two DIMMs in the parts manual. This is so confusing and why didn't what I need come in the box? This is ridiculous.
        1503MB0UN0
        • Samanator
          • Sep 2017
          • 579
          Is this fax card brand new out of the box or did come from another machine?
          • Necrocannibal
            • May 2008
            • 212
            Brand new out of the box, there was no DIMM or instructions on how to install a DIMM but in the parts manual there is a DIMM for it and I actually think it is part number
            303MB94030
            • Necrocannibal
              • May 2008
              • 212
              Orderd that part and hope it's the issue.
              Sent from my SM-N986U using Tapatalk
              • kuby
                • Oct 2007
                • 1414
                Thanks!
                EDIT*
                1503MB0UN0
                Yes installing the DIMM fixed the issue.
                • Necrocannibal
                  • May 2008
                  • 212
                  Yes installing the DIMM fix the issue.
                  Thanks! It did for me as well, still not sure why it wasn't in the box.
                  • copiertec
                    • Jan 2016
                    • 2211
                    Which Dimm did you wind up ordering? was it the 1503 or the 303M Dimm?
                    • kuby
                      • Oct 2007
                      • 1414
                      Kyocera 1503MB0UN0 (MM-16-128) 128MB Fax Memory
                      • logrady2331
                        • Feb 2011
                        • 301
                        Gary in Phoenix az. i am trying to install fax system 10 in both a 356ci and a 406ci and am getting that same c0620 error code after install of board. NO dimm comes in the box with the fax system/board. What the Heck. I'm looking for this magical dimm part number myself
                        • kuby
                          • Oct 2007
                          • 1414
                          It is posted. Yes my previous post.
