Ecosys M2540dn Fuser Mod
  • jewen25
    • Mar 2009
    • 197
    Good Day i counter a problem fuser section specially in fuser film to this Model,its there any modification to the fuser from fuser film to fuser roller or any mod.to the Set?
    ERROR HELP ME AND HELP YOU
  • Ropariva
    • 701
    None that work. Check with your local Kyocera support and see if there is an extended warranty offered on this model. It may be cheaper to buy a new P2040 printer than buying a fuser.
    • jewen25
      • Mar 2009
      • 197
      Thank You
      • Lunatech
        • Oct 2012
        • 217
        I just take out the cloth from inside the fixing film and put it together like it was a Canon or HP. Provided the film isn't trashed I have saved many using this method. You will need high temperature grease, I use Krytox, there are many. I won't go into taking apart and all that. Any competent tech will be able to figure it out.
