C2950
  • brancas
    • Jul 2009
    • 80
    C2950
    Having a c2950 on a TA3051ci error pointing to the motor control pwb. Also the machine is indicating paper jam and main cover open symptoms similar to a C980 error which is the low voltage PWb. Replaced the motor control PWB. Problem still exists. Any suggestions?
    • 23009
    Re: C2950
    The manual points to a communication issue between the motor control PWB and the engine PWB.
    If you're not ready to go for the engine board yet, you could try the harness in-between. The manual also mentions firmware, and it can't hurt ... but probably won't help.
    • brancas
      • Jul 2009
      • 80
      Re: C2950
      [QUOTE=blackcat4866;1942130]The manual points to a communication issue between the motor control PWB and the engine PWB.
      Did not try the harness. Will let you know how that turns out.
      • brancas
        • Jul 2009
        • 80
        Re: C2950
        tried the harness and feed pwb 1. turned out to be the engine board. thanks for the advice.
        • KYO_OEM
          • Aug 2011
          • 721
          Re: C2950
          are you shure for C2950 instead of maybe C6950?
          look for the attachment and check flatcables.
