Hello guys i have the above machine with weired error programe loading and after some time error CFB 31 pops
Kyocera km 5050 error program loading and cfb 31
Tags: None
Would your customer be printing webpages directly out of the browser? That is a common outcome. A workaround is to save that webpage as a PDF, then print the PDF. =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^= -
Is that a 20 year old machine? Is that a falcon 3? If it is there was a dim under the control panel that can be the issue. Need reseated of replaced. I thing the writing on them needed to be in yellow?๐ 1Comment
I read the model and that code....and that stupid chip flashed in my mind. Thin gold plating on the contacts of early production chips."Being ignorant is not so much a shame, as being unwilling to learn" - Benjamin Franklin
