Kyocera km 5050 error program loading and cfb 31
  • COPIERTEC ASSOCIATES
    • Aug 2011
    • 279
    Hello guys i have the above machine with weired error programe loading and after some time error CFB 31 pops
    • 23008
    Would your customer be printing webpages directly out of the browser? That is a common outcome. A workaround is to save that webpage as a PDF, then print the PDF. =^..^=
    • Tonerkiller
      • Oct 2012
      • 668
      Is that a 20 year old machine? Is that a falcon 3? If it is there was a dim under the control panel that can be the issue. Need reseated of replaced. I thing the writing on them needed to be in yellow?
      • Munter
        Member
        • Jul 2011
        • 23
        Also advisable to "print as image" to stop any errant coding getting through.
        • PrintWhisperer
          • Feb 2018
          • 472
          Spot on!
          I read the model and that code....and that stupid chip flashed in my mind. Thin gold plating on the contacts of early production chips.
          "Being ignorant is not so much a shame, as being unwilling to learn" - Benjamin Franklin
          • kyotechnz
            • Mar 2019
            • 145
            Or it is time to put on your salesmen hat and upgrade them.
