Battling IPP drivers after MS updates? This says it will keep them from loading.
  • kuby
    • Oct 2007
    • 1408
    This says it will keep IPP drivers from loading:
    1. Press “Windows + X” and select “System”;
    2. Under “Related Setting” or “Device Specifications”, select “Advanced System Settings”;
    3. Select the “Hardware” tab;
    4. Select “Device Installation Settings”;
    5. Select “No (your device may not work as expected);
    6. Click “Save Changes” and the “Ok”.
    7. Restart and change to proper drivers.
    Worth a try. So far so good after a month.
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1887
    Thanks for that. I've been successful with accomplishing on the MFP side, but there are too many items that have to be disabled, then other functions stopped working.
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
    • kuby
      • Oct 2007
      • 1408
      Sorry, have not had that problem?
      • Scottb
        • Apr 2013
        • 306
        I've just set which machine the customer wants as default and this seems to help as well
        • nathicana
          • Aug 2008
          • 335
          To stop Windows from creating unwanted drivers just uncheck this box
          • PrintWhisperer
            • Feb 2018
            • 472
            You can also disable the WSD and IPP protocols on the device.
            "Being ignorant is not so much a shame, as being unwilling to learn" - Benjamin Franklin
            • dalewb74
              • Feb 2018
              • 1153
              i agree with nath... above... then just use the print drivers from the manufacturer. been doing this the past few years. i don't need windows installing every printer on the network. i only need just the one or two that i use. same goes for my customers that i install new equipment for.
