ERROR CODE C6610
  • quitech
    • 82
    ERROR CODE C6610
    Hi every one,
    Please i need help from you guys, the kyocera ecosys m 2040dn i supply to a customer is showing error code c6610, please how can i clear the code. your help will be highly appreciate.
    thanks
    Quitech
  • Ropariva
    • 680
    Re: ERROR CODE C6610
    Originally posted by quitech
    Hi every one,
    thanks
    Quitech
    Likely the Fuser belt has seized. Replace fuser
    • ntbann
      • Jan 2012
      • 628
      Or disassemble fuser remove felt pad. Lube sleave with hp high temp grease and reassemble.
      • dalewb74
        • Feb 2018
        • 1157
        what does the service manual say whenever you look in it???
        • ntbann
          • Jan 2012
          • 628
          Without looking fuser lock.
          • fishleg
            • Mar 2009
            • 426
            Very curious to know how long it takes to grease these fusers? What readily available grease works?
            • trunghuynh20202020
              Technician_kyo
              • Oct 2021
              • 22
              6610 m2040dn.jpgC6610 m2040dn.pdf
              You try the steps according to the sm document, good luck
              • copier tech
                • 8172
                Hi every one,
                thanks
                Quitech
                Could simply be a sheet of paper stuck in the fuser.
