New Windows Update Now Kyocera Twain Driver Scanning Shadows Around Letters
  • tecchie
    • 118
    Weird problem with a customers 5526 but im sure it happens with any Kyocera model. Since the latest Windows update some point this past December the latest kyocera twain driver scans with on scans shadowing around lettering. Things were fine before the update. Barely noticeable on the scan itself unless you enlarge it but when printed back to machine it is horrible. Whats funny is if its printed out on an HP its fine or doesnt show. At that point figured it was a print driver setting. Things ive already tried
    All forms of Windows 11 kyocera print drivers (kx, pcl etc.)
    Using current version of Kyocera Quick Scan Software
    Customer using Adobe but tried opening document with different programs with same result.
    Tried scanning with different formats. No change.
    Tried older Twain driver with same results
    Pretty much ruled out everything and down to something that the twain driver is doing to the document that is only recognized on a Kyocera machine printing it out. Almost like the scan is putting a highlight or trying to around the letters and pictures. Looks like a double print.
  • Dark Helmet
    • May 2009
    • 838
    Have you tried using the Kyocera Print Center on the Microsoft store? Might be a work around.
    You can scan with that.
    • yoel fiszerman
      • Feb 2025
      • 1
      Try to change the KX driver to work in PCL 5 mode and set the color mode in the driver to automatic
      • tmaged
        Owner/Service Manager
        • Oct 2008
        • 1873
        New TWAIN driver released today may fix it.
        Hope that helps !
        -Tony
        www.dtios.com
        Become a fan on Facebook
        • Samanator
          • Sep 2017
          • 576
          I only use the KX driver and never have problems
