U485
    • 16470
    U485
    I've noticed that some Kyocera machines don't have the color tables loaded under U485. Is this something that can be done by the tech and where may one find the files to do this?
  • Ropariva
    • 695
      • 16470
      Re: U485
      Thanks for the info., Ropa.
      • tmaged
        Owner/Service Manager
        • Oct 2008
        • 1898
        Re: U485
        Yes, if memory is correct, the 0 series and possibly 1 series didn't have them loaded by default. The 2 and later do have them preloaded.
        Hope that helps !
        -Tony
        www.dtios.com
        Become a fan on Facebook
        • Samanator
          • Sep 2017
          • 579
          Re: U485
          If you can get on the Kyocera site, the color profiles can be found under Firmware.
          For the two and three series, I had to look at the 4052ci and 4053ci before I could find them. I couldn't find anything for the four series.
          I downloaded what I could and filed them away in case I need them at a later date.
            • 16470
            Re: U485
            Thanks for the info and to everyone that responded. I had never noticed it before but the color table is in the firmware but it has to be installed under U485. I installed it and it's back. Thanks again.
