Kyocera m6635cidn. Failed firmware update. Looks to be bricked.
  • paulv
    • Feb 2025
    • 5
    I have a Kyocera M6635cidn.
    Attempted a firmware upgrade - used the SoftwareUpgradeTool application and the firmware file: FirmwareUpgradePackage_ECOSYS M6630cidn M6635cidn_v04.03.0020.fwp
    Available on Kyocera's website: https://www.kyoceradocumentsolutions.co.uk/en/support/downloads.name-L2diL2VuL21mcC9FQ09TWVNNNjYzNUNJRE4=.html#tab=appl ication
    It looks like the update failed - ended with an error: Cannot verify the installed version.
    I'm wondering if my laptop went to sleep mid-way through and lost network connectivity or something like that.
    Restarted the printer. Goes through what sounds like a normal start up routine. Displays welcome on the screen for a bit, then the Ecosys logo and it doesn't go any further.
    None of the buttons seem to do anything.
    Can't ping it, Can't access its web admin page.
    Unplugged it and left it off for a few minutes and tried again - same thing.
    Bugger. Looks to be bricked.
    Is there a way to rescue a bricked Kyocera printer?
    I see it has a USB port - can another attempt at loading firmware be made via USB? How does that work?
    Hoping someone can help.
  • Slammers
    • Feb 2019
    • 136
    Put the Firmware files directly into the root directory of an EMPTY FAT32 formatted USB stick. Make sure the machine is OFF, put the USB in the USB slot, then power up the device.
    Your USB stick should look like this:
    (I.e copy the contents of the "Firmware" folder directly to the stick, don't copy the entire folder, just the contents.)
    • paulv
      • Feb 2025
      • 5
      All sorted - Thank you.
      A friendly person on Reddit sent me the correct firmware update files - the only file available on the Kyocera site wouldn't work via a USB stick.
      Firmware update files loaded onto the root of a USB stick formatted in FAT32 format, inserted into the front USB slot did the tick.
      Started up the printer, and it loaded the new firmware itself.
      • Slammers
        • Feb 2019
        • 136
        Ah excellent. Thank you for the update.
        • Mosleh
          • May 2025
          • 2
          Apparently, I have the same problem, can you please send to me the same files to be placed on FAT32 memory stick for C3566i
          • copier tech
            • 8169
            Happy to help. Drop us an email.
            www.printerfirmware.co.uk
            • Mosleh
              • May 2025
              • 2
              Thank you very much, Firmware update files loaded onto the root of a USB stick formatted in FAT32 format, inserted into the front USB slot did the job.
              • repkin
                • Mar 2024
                • 1
                Friends, help me out. I need your help. Also need files to update from usb. Very much your help.
