Company logo
  • charge leak
    • Mar 2020
    • 15
    Company logo
    Hi all, does anyone know how to put our company logo onto the home screen on the Taskalfa C2553 machines.
    Thanks in anticipation
    Charge Leak.
    • 16391
    Re: Company logo
    First you have to create the jpeg in the correct size, load it on a USB stick and then run U224.
    • charge leak
      • Mar 2020
      • 15
      Re: Company logo
      Thanks for the prompt reoly, its a stupid question I know, but what is the required size ? yes the screen size.... The lunatics are running the asylum...
        • 16391
        Re: Company logo
        I misspoke. It's been a while since I've done this but here's what you need to know:
        Copy the files to an USB-stick and load the files to the machine using U224. The files are :
        callwin_ext_image.png 180x200pix max 1Mb
        callwin_ext_mes_detail.txt
        callwin_ext_mes_top.txt
        opening_ext_image.png 800x400pix max 1Mb
        Use an application like Irfanview to format your image to 800x400 pixels, .png file format, and named exactly as specified. Use simulation U224 to import the image.
          • 23008
          Re: Company logo
          Maybe these documents may help:
          • copier tech
            • 8144
            Re: Company logo
            Charge Leak.
            Do you want to create a home screen logo or boot screen logo?
            Background operation panel
            • dalewb74
              • Feb 2018
              • 1153
              Re: Company logo
              i agree with the other post. and it must be exact as specified. file size and type, if those are off it won't work. and i don't remember the kyocera model. but i did changed that file before, once it is changed it can't be changed back to the default.
              • charge leak
                • Mar 2020
                • 15
                Re: Company logo
                Thanks so much for your help.
                Charge Leak.
                • PerlaWest
                  • Feb 2024
                  • 1
                  Re: Company logo
                  Getting your company logo on those Taskalfa C2553 machines can be a bit tricky.First off, you'll wanna make sure your logo is in the right format. I'd recommend using an AI SVG generator to convert it into a scalable vector graphic. That way, it'll look crisp and clear no matter what size you need it.Once you've got your logo in the right format, it's all about navigating the machine's settings. You'll likely find an option somewhere in the menu to upload custom logos or images. Just follow the prompts, upload your logo, and bam—you'll have your company branding front and center on those machines in no time.
                  • Tonerkiller
                    • Oct 2012
                    • 668
                    Re: Company logo
                    The directions are in the manual.
