FS-4200DN, Fuser
  • Hansoon
    • Sep 2007
    • 3384
    FS-4200DN, Fuser
    Guys how long would a Kyocera noob need to replace the fuser of a FS-4200DN?
    Is the #FK-3130/302LV93166, 230VAC, the right part number for this machine?
    Hans
  • piksel1983
    • Oct 2018
    • 38
    Re: FS-4200DN, Fuser
    Hans
    Replacing only unit without changing heating roller takes ~5 min
    Wysłane z mojego Mi 9 SE przy użyciu Tapatalka
    • Hansoon
      • Sep 2007
      • 3384
      Thanks, do you have the instructions how to do it and which screws and harnesses has to be removed and FK-3130/302LV93166, 230VAC is the right part number ?
      Told you "I'm a Kyocera noob...."
      Hans
      • patrickjlc
        • Feb 2015
        • 225
        302LV93114 i think is the one for 220v.
        It us easy, remove the rear door, the little side panels, 1 screw for the cover by the electrical plug. Then 2 screws for the heater, 2 grey connectors, and two power connectors at the bottom.
        Only need a phillips and maybe a flat to get the doors out.
        Sent from my motorola one 5G UW using Tapatalk
        • Ropariva
          • 674
          Hans
          This should about cover it. Important to plug it in prior to fitting the new fuser to release the pressure cam or you will struggle to get it to go in.
          • GeneOR95
            • Feb 2018
            • 161
            Hans,
            Sent you a PM with a link to a download for the service manual.
            Gene
            • avio2
              • Jul 2010
              • 150
              sure?????? for me 20min
              you are a very good tech if finish in five minute
                • 23008
                Time seems to be relative.
                I've had other techs tell me that they can do a full color PM in 60 minutes, and maybe they can ... but not if you clean anything, not if you test anything, and not if actually install the parts. The same full color PM seems to take me 2+ hours. It think it might just be an exaggeration. =^..^=
