ARM Printers
  • monstercopier
    • Jun 2019
    • 60
    ARM Printers
    Hi I am in an urgent need of Kyocera printers that support ARM64 processors for printing. If not Kyocera are there any other brands?
    • 23008
    I'll be the first to say, I don't recommend using generic drivers in any situation. However, Microsoft does have a generic print driver. I'm sure you will see diminished functionality (like the ability to recognize optional paper sources or finishers), but maybe it will suit your situation.
    I have already tried to install several printers on my Surface Pro X. After the successful installation they do not print because none of them has compatibility with ARM64 Windows 10, only for Android.  I gave up trying to install and now I ask the help …
    • PrintWhisperer
      • Feb 2018
      • 471
      BC has you on the right track..the hardware is not the problem, it's the compatible SOFTWARE that you need. Print Drivers are built to live in certain processor environments. 64bit vs 32bit, Intel vs MAC (Motorola, etc.) and then we get to the ARM processor which is NOT widely supported for printing.
      As BC says, any PCL or PS driver you can get to run on ARM will send data to ANY printer and that printer will render it.
      However ANY random driver is likely not going to have device specific functions so will be limited in functionality
      "Being ignorant is not so much a shame, as being unwilling to learn" - Benjamin Franklin
      • monstercopier
        • Jun 2019
        • 60
        Thank you all for this advice.
        I did find this, so I am hoping it works please see article below. They mention ARM64 as an operating system. Fingers crossed it works.
        Kyocera Printer Setup Tool User Guide
        • ihatefinishers13
          Senior MFP Technician
          • Feb 2020
          • 695
          I had no issues setting up the KX Driver on an ARM based laptop... We bought a device specifically so we could test out software and printing from ARM. Just grab the latest driver
          • rickirobert
            • Mar 2019
            • 32
            Le KX for ARM SNAPDRAGON is ok, i test it on FS-3900 and 6052ci
