Calibration marks on prints TA5052ci (Utax 5006ci)
  • KyoServiceManager
    • Oct 2017
    • 30
    #16
    Re: Calibration marks on prints TA5052ci (Utax 5006ci)
    Originally posted by tmaged
    Tried a belt, transfer HV PWB and Engine PWB on a 3252ci, and didn't resolve it. Anyone fix theirs ?
    Did you try the shutters I mentioned in a previous comment? Had this same issue on the same model yesterday and shutters were the issue.
    "If a cluttered desk is a sign of a cluttered mind, of what, then, is an empty desk a sign?" -Einstein
    • tmaged
      Owner/Service Manager
      • Oct 2008
      • 1889
      #17
      I did clean the ID sensors, but I did not reseat the connector.
      Hope that helps !
      -Tony
      www.dtios.com
      Become a fan on Facebook
      • KYO_OEM
        • Aug 2011
        • 721
        #18
        If you have trouble with ID sensors you must get C7601 or C7602.
        Visible on event log only. (similar to C761x and C7620)
        • tmaged
          • Oct 2008
          • 1889
          #19
          Cleaned and reseated the ID sensors and then replaced the unit and it's still not cleaning.
          Picking it up tomorrow to continue troubleshooting it in our office.
          Hope that helps !
          -Tony
          www.dtios.com
          • buzz
            • Aug 2013
            • 288
            #20
            I had this exact same problem. I replaced transfer belt, the little transfer connect PCB located in the front, and HV PCB.
            You may have already checked this but thought I mention anyway.
            Calibration Marks not being cleaned off the belt in time for a clean print job.
            The problem ended up being the black spring-loaded high voltage housing. The long STRAIGHT part of the contact springs were out of its track (not tucked in properly inside the little tabs of the housing). I couldn't recognize the problem until I fully removed this part from the machine. see pic. Check all spring contacts for deformity.
