Calibration marks on prints TA5052ci (Utax 5006ci)
  • lanierboy
    • 149
    Hi All,
    Bit of a strange one, We have a machine where the calibration marks are showing on the print outs.
    so far we have changed the Transfer belt assembly and checked all the connections and drive.
    All is ok but it still happens, not every print but often enough.
    Anyone had this before? or know of a fix??
    nothing in the bulletins or firmware (but we did load the latest just in case)
    Regards
  • KYO_OEM
    • Aug 2011
    • 721
    Re: Calibration marks on prints TA5052ci (Utax 5006ci)
    we have had 1 similar case and finally new transfer high voltage pwb solved the problem.
    New TR, waste toner forwarding unit, feed image pwb and feed drive pwb didn`t solved it.
    • pascalb.
      • Aug 2016
      • 47
      Hello,
      it is a problem of improper cleaning of the belt.
      if the problem is the same with a new belt i think the waste toner is clogged.
      did you have C2810 codes.
      have a good day.
      Do not lament,
      do not mock,
      do not hate,
      but understand.
      • KYO_OEM
        • Aug 2011
        • 721
        @pascalb
        normally good idea, but if the transfer belt is new, there is no stucked waste toner inside and we can`t get this problem until the belt waste area is full again.....
        greetings to Eric and Jean
        • lanierboy
          • 149
          Thank you for the advice, I will place one on order now. :-)
          • KyoServiceManager
            • Oct 2017
            • 30
            I've had a few different models do this from the TA 306ci on up and almost every time its been solved by cleaning / reseating connectors for the ID sensors & shutters. Generally, I will hit that whole registration section with a vacuum and then manually swab the sensors to clean them. Check event report for error codes 7601 or 7602 and check for color registration errors. Sometimes just doing the calibrations and manual color registration will help. Good Luck!
            "If a cluttered desk is a sign of a cluttered mind, of what, then, is an empty desk a sign?" -Einstein
            • copier tech
              • 8172
              Originally posted by lanierboy
              Hi All,
              Regards
              [ATTACH=CONFIG]51313[/ATTACH][ATTACH=CONFIG]51313[/ATTACH]
              There was a bulletin on this, try updating the firmware.
              • Ropariva
                • 680
                • KYO_OEM
                  • Aug 2011
                  • 721
                  1.
                  transfer cleaning blade??
                  If i am right, there is a cleaning brush instead of a blade.
                  Take a look for U107/ primary transfer cleaning voltage adjustment
                  For a blade no voltages needed.
                  2.
                  primary transfer belt would replaced without success
                  new belt with flipped "cleaning blade" i don`t think so.
                  3.
                  From my experience, we are missing the needed cleaning power supply for the brush or missing ground.
                  This could be the reason. We have had similar cases on other systems in past. (e.g. Saturn, Venus, Mebius, Gemini)
                  4.
                  issues in past:
                  bad contact from the spring for cleaning voltage/ ground (right side on pwb at this system)
                  take care for parts tc terminal assy, spring HV CLN/ spring HV Transfer CLN Bias
                  broken transfer high voltage pwb
                  worst case: broken engine pwb
                  • lanierboy
                    • 149
                    Thank you all for your replies and suggestions.
                    As an update/reply,
                    The latest firmware was applied and didnt fix the issue
                    The new high voltage board did not fix the issue.
                    All connectors are good and a new transfer belt was fitted
                    We are now going to go back with an Engine board.
                    • Ropariva
                      • 680
                      • tec966
                        • Mar 2009
                        • 42
                        Can you give me the bulletin number, please ?
                        Thankyou
                        • buzz
                          • Aug 2013
                          • 288
                          Hi All,
                          Regards
                          What was your fix on this, I posted a same problem with a 3252ci. Thanks
                          • Mr2crazed
                            • Jun 2014
                            • 35
                            As an update/reply,
                            Did the engine board resolve the issue?
                            • tmaged
                              Owner/Service Manager
                              • Oct 2008
                              • 1888
                              Tried a belt, transfer HV PWB and Engine PWB on a 3252ci, and didn't resolve it. Anyone fix theirs ?
                              Hope that helps !
                              -Tony
                              www.dtios.com
                              Become a fan on Facebook
