FS4200 Eject/Feed Shaft section will not feed paper
  • rdyjnkns
    • 135
    After I replaced the fuser assembly in my FS4200 (due to a PCQ issue), the EJECT/FEED SHAFT ASSEMBLY will not accept the print job from the fuser. In other words, no gear movement. I installed the original fuser assembly, no joy. I replaced the R-LPWB assembly with a known good unit, still no joy. I check the schematic and it does not show the voltages from the R-LPWB assembly to the motor. Any assistance would be deeply appreciated.
  • DRichard
    • May 2008
    • 482
    Re: FS4200 Eject/Feed Shaft section will not feed paper
    Did you do this? (from the manual...)
    Caution: when refitting the fuser unit, performthe following procedures.
    (1)Turn on the power switch while opening the
    rear cover after removing the fuser unit.
    (2)Turn off the power switch after 5-second or
    more progress.
    (release state of fixing pressure)
    (3)Refit the fuser unit.
    "Enjoy every sandwich."
    -- Warren Zevon
      • 23009
      What jam code? =^..^=
      • spw
        • Mar 2015
        • 62
        drichard's idea is my best guess as well. The cams sound like they are in the up position and not fully seated. I would also cheat the door switch and eliminate the door possibility. But yes Jam code would great
        • rdyjnkns
          • 135
          There is no jam code displayed. And I have not been able to access the error log as per the serviced manual (see attached).
