Check Hard Drive (U989) and memory. Maybe put known good ones in the copier to make sure.
If you can backup the copier and do a U21. Reset up.
I would try this before going to a main pcb.
check inbuilt pf unit for stucking paper.(cass 3+4)
Take out both drawers, remove feed unit B1 and check.
we have had several similar cases in past, it`s a well known problem for our techs.
The time I saw it, it was an Alphard2, and the paper was crammed behind the bridge unit.
Ive seen that bridge unit paper jam as well. Print jobs just blink without printing and no error code on screen. Like the machine just doesn't know what to do with that kinda jam.
It's a know bug in the firmware that, AFAIK, has never been addressed.
