kyocera 3500i hazy line
  • bruce 49dcs
    • Jan 2017
    • 140
    my customer has a hazy gray line a third of the way across the page in the print direction its not the optics because sometimes the line is gone and it gets worse on multiple copies the drum looks ok and so does the charge roller but it looks like a hot spot so i really think its the drum just trying to get a second opinion because the drum unit is expensive and i would hate to sell it to them and still have the line thanks in advance bruce
  • Samanator
    • Sep 2017
    • 579
    Re: kyocera 3500i hazy line
    Does the line repeat?
    Do you have a sample we can see?
    • bruce 49dcs
      • Jan 2017
      • 140
      its one solid actally hazy straight line from leading edge to trailing edge in the print direction
        • 23008
        I think I'd like a visual sample please:
        • copykat93
          • Oct 2021
          • 277
          Do you get this hazy gray line from doing internal prints? Can you print pages to the machine & see what it looks like that way also? Is this only happening while doing copies?
          • bruce 49dcs
            • Jan 2017
            • 140
            copies and prints from pc thats why i suspect the drum also it comes and goes so I dont think its mirrors or laser its got to be the drum or the dv unit but im thinking if its a forign object in the dv it would move side to side but its not what about a hot spot on the charge roller hmmm also any example is at the customers office and my scanner is on loan
            • Santander
              • May 2009
              • 768
              Did you check the paper dust wiper for the registration roller? Have had cases where the paper dust creates a string and interferes with the developer and then breaks off and the copies are fine. See this mostly with clients that use recycled paper.
              • Ropariva
                • 674
                • Gab
                  • Aug 2015
                  • 671
                  check also heat roller surface.
                  You can stop printing before paper passes the hot roller. Check the image. If line exist it is not the fuse unit.
                  Else check the drum surface at the point that line exist , searching for a scratch line.
                  Else problem in dev unit.
