TA 4550ci Can you shine fusing sleeve to make last longer with fuser sleeve oil
  • Doug James
    • Jan 2012
    • 935
    [CQ] TA 4550ci Can you shine fusing sleeve to make last longer with fuser sleeve oil
    I replaced a customers fuser (TA 4550ci) with brand new one because in the morning the fuser would put double images on the copies for the first 10 or so copies. The fixing sleeve has a dull image and was wondering if you could shine it up with sleeve grease. Here is why I ask... A few years ago I had the bright idea of rebuilding these fusers. I bought several sleeves that included fuser oil in a tube. (I since abandoned the rebuild idea) but am curious what the tube of oil was for and thinking that this may be it... To shine fusing sleeves so the image would leave the sleeve easier. Any thoughts on this ? Thanks so much !!!
    • 23010
    Re: TA 4550ci Can you shine fusing sleeve to make last longer with fuser sleeve oil
    If you've got a weird fusing issue, you might take a look at the power coming in. I struggled with a KM-3051ci with a strangely intermittent fusing issue. After changing the fuser twice, the IH coil, and the IH board, eventually I followed the power cord under a cube wall to a 800W UPS, which then ran under another cube wall to another 800W UPS, which then plugged into a floor outlet. When the UPS's were removed the issue never re-occurred. =^..^=
    • Doug James
      • Jan 2012
      • 935
      Thanks so much !!!, I will take a look at that
