Ecosys M2540dn copy problem
  • jewen25
    • Mar 2009
    • 197
    I got ecosys m2540dn,i replace new fuser film,but when i copy that txt is ok but if you touch its erase,i check all the parts like halogen lamp its Ok, any suggestion for this issue,thank You
    ERROR HELP ME AND HELP YOU
  • Ropariva
    • 676
    Not an easy fuser to rebuild. I’d suspect you have no pressure if your toner is wiping off. One test for fuser pinch is to run a solid black print and stop it mid way thru the fuser. Let it sit for a minute and remove You should have a 3-5mm strip that is fully fused and shiny compared to the rest. If you don’t have this then you have no pressure. Time to go over your work.
    • copykat93
      • Oct 2021
      • 277
      Those fusers are a bear to rebuild, IMO, not worth the effort. Do yourself a favor & put in a new Genuine Kyocera fuser & you will be much happier, even thou they're pricey, its the best way to go.
      • jewen25
        • Mar 2009
        • 197
        Thank you for reply i try other fuser set,and the result still same result,i suspect the power supply board,or the Triac?
        • jewen25
          • Mar 2009
          • 197
          Thanks for reply,maybe an option to go to genuine,but i try to resolved this problem
          • KYO_OEM
            • Aug 2011
            • 717
            Looks like wrong fuser pressure.
            I`m wondering a little bit why you do not get C6xxx error
            Does the fuser pressure release motor is working well?
            Start printing by open cover and check if it works, you can see and hear if it works.
            Also check wirings for motor and sensor.
            • copyman
              Owner / Technician
              • Sep 2005
              • 4708
              Agree fuser pressure is probably the issue. The temp must be ok or it would code out? Aftermarket fuser film? Is film turning (fuser grease?)
