Kyocera emails using Office 365
  • kuby
    • Oct 2007
    • 1410
    Microsoft updated security setting for Kyocera copier sending emails via Office 365.
    We had customers that are sending emails via Office 365 from the copier and have been for some time. Then suddenly they started getting validation error. On testing the setting on the copier side they customer starting getting a "0 x 3102" error. Doing some research found a article about Microsoft updating the security and settings needed to be changed on the copier. Here are the NEW setting for the copier that need to be put in under Clientside settings:
    • 30421
    Re: Kyocera emails using Office 365
    Had the same problem a few weeks ago
    That's what I did to fix it.
    • rreynolds
      • Feb 2022
      • 3
      I also have the same problem. I tried all these settings. I hit the test but and it says good to go. Try sending from printer get an error message.
      • copier tech
        • 8195
        Been seeing this a lot now, a firmware update fixes the issue. Setting needs to be TLS1.2
        • rreynolds
          • Feb 2022
          • 3
          That's the problem. They all are very out of date in firmware. I'm not paying for a tech to come out. I hate these printers. All the other printers I can download firmware from the manufacture. But they want me to pay for some to come and do it.
          • ntbann
            • Jan 2012
            • 631
            I dont know what other manufactures you are talking about but the only one I know of that lets consumers download firmware is HP.
            • richs
              • Nov 2008
              • 266
              Xerox lets the customers download firmware.
              • rreynolds
                • Feb 2022
                • 3
                My Toshiba will auto install new firmware.
                • copier tech
                  • 8195
                  We can supply the latest firmware for a small fee, it is a simple process so you can update it yourself.
                  Printer & Copier Firmware - www.printerfirmware.co.uk.
                    • 16455
                    I'm having this problem on a 3551ci.
                    What is the latest firmware? I have version 2N4_2000.007.451 2020.03.17
                    • ThisPete
                      Too old to care
                      • Jun 2014
                      • 233
                      07.05.0060..
                      The above quoted is not a full firmware version.. merely a subset version...
                      • copier tech
                        • 8195
                        Give us a shout if you need the update.
                        TASKalfa 3051ci, 3551ci, 4551ci, 5551ci
                        Version: 07.05.0060 (2020-03-17)
                        Release Date: 2020-04-17
                        Main Frame Version
                        MAIN (FS) 2N4_2000.007.451 (NEW)
                        MMI 2N4_7000.007.405
                        PANEL 2N4_7200.001.017
                        BROWSER 2N4_F000.002.001
                        OCR 2N4_L000.001.005
                        LANGUAGE BR 2N4_81BR.001.050
                        ENGINE 2N4_1000.005.001
                        SCANNER 2N4_1200.005.001
                        MOTOR 2MN_1400.002.001
                        IH 2LC_1A00.002.001
                        Color Table 2N4_GZ00.001.002
                        Copy Color Table 2N4_KZ00.001.003
                        FAX 3N6_5400.B06.001
                        FMU J00_E00C.006.011
                          • 16455
                          Main Frame Version
                          IH 2LC_1A00.002.001
                          Thanks. Payment sent.
                            • 16455
                            The updated firmware did the trick.
                            • copier tech
                              • 8195
                              Great, thanks for the feedback.
