307ci - How to remove Primary Transfer UNIT
  • M.Z.67
    • Jun 2025
    • 3
    [Misc] 307ci - How to remove Primary Transfer UNIT
    KYOCERA 307ci - I need to remove the primary belt from this machine, I consulted the manual and it seems like you just have to pull it, but it won't come out. Can anyone confirm? Or is there a trick? Thanks.
    This gallery has 1 photos.
  • Munter
    Member
    • Jul 2011
    • 23
    It's been a while since I looked at a Kyocera but I think you just have to lift it slightly and urge it over a lip/resistance.
    • ThisPete
      Snr/troubleshoot/network
      • Jun 2014
      • 236
      They can be a struggle to get out sometimes.. I have in the past thought something would break, or that I would pull the machine over onto myself..
      #animalmode needed... 👍
      • M.Z.67
        • Jun 2025
        • 3
        Then I'll take some courage... You're all very kind, thank you.
        • ThisPete
          • Jun 2014
          • 236
          Good luck,.. and be 'brave'... 😀
          • ihatefinishers13
            Senior MFP Technician
            • Feb 2020
            • 716
            I know it sounds weird, but I usually cross my arms and then push down a tiny bit with my thumbs up to get it out. I end up with more room to grab it since it's close to the front and rear walls.
            • Lunatech
              • Oct 2012
              • 215
              Just grip it and rip it.
              • CoreyAbels
                • Dec 2014
                • 92
                Better yet, grip it and try NOT to rip it 😂😂😂😂
                • Lunatech
                  • Oct 2012
                  • 215
                  Yea, that's probably better.
