Taskalfa 300ci SMTP SSL
  • Sydewinder
    • Feb 2022
    • 2
    [Misc] Taskalfa 300ci SMTP SSL
    Have an old Taskalfa that I've been tasked with setting up for a new client. Doesnt seem to have SSL as an option in the SMTP setup. Can anyone confirm that a firmware update would add that feature to this machine. Don't have access to the firmware from Kyocera but would like to confirm it's a solution that will work before paying for the firmware update. thanks in advance.
  • Ropariva
    • 676
    • Sydewinder
      • Feb 2022
      • 2
      Re: Taskalfa 300ci SMTP SSL
      Thanks for the reply. Was afraid of that. File scan utility most likely for the PC User but SOL for the couple people that use MacOS. New machine it is.
      • Samanator
        • Sep 2017
        • 579
        Best scanning option for this machine is scan to a USB memory stick and use the sneaker network (IMHO).
        • dalewb74
          • Feb 2018
          • 1153
          you can setup scanning on that model using filezilla server.
