5054ci dark lower left corner
  • Scottb
    • Apr 2013
    • 308
    this machine originally had a C3800 error, and the lens corrected this issue. some weeks later i get a call saying that the lower left corner is dark from the glass only. I made several adjustments and ended up ordering another lens assy. after installation everything looked good no shading in the corner...until today. has anyone seen this and can share the fix .
  • CoreyAbels
    • Dec 2014
    • 92
    I just ran into this EXACT issue last week, still hunting for a resolution though. I will post an update when I have one
    • Scottb
      • Apr 2013
      • 308
      Kyocera Tech support suggested, that if i had the original lens(which by chance i did) to remove the board from it, put the board from the new lens onto it, and reinstall the original lens with the new board. I just have done this and it appears to work, but the last one did for a few weeks.
      • tmaged
        Owner/Service Manager
        • Oct 2008
        • 1896
        Did you use the charts and calibrate it in U411 after replacing the lens unit ?
        Hope that helps !
        -Tony
        www.dtios.com
        Become a fan on Facebook
        • Ropariva
          • 693
          I’ve had this when a machine has arrived damaged and the scanner assembly is no longer sitting flat on the frame. I found there is a wedge that adjusts the height of the scanner unit on the RHS. These units had been damaged. I replaced parts 2, 3 and 25 from a scrapped machine and it solved my problem.
          This gallery has 1 photos.
          • CoreyAbels
            • Dec 2014
            • 92
            The new ISU/Lens immediately produced this problem and after double and triple checking my ISU alignment I eventually swapped the new board into the old lens and the problem mostly went away (including the original C3800 error).
            My coworker went out with a new ISU and cables and neither resolved the issue. It appears to me that the scanner isn't square and/or level but I haven't had a chance to go back out on the machine.
            • CoreyAbels
              • Dec 2014
              • 92
              Absolutely, and it failed both the Auto and Manual adjustment methods.
              • CoreyAbels
                • Dec 2014
                • 92
                This tracks with the symptoms, however this machine has been in the field for 2+ years without issue up until the recent Main PWB and now ISU failure. I will have to check this when I go back out 👍🏻
                • Ropariva
                  • 693
                  Someone copied their butt? 😂.
                  You may have success adjusting the sliding wedge. On mine I stripped off the scanner plastic covers and put a straight edge (long ruler) on LHS and RHS and sighting along the two the twist was obvious.
                  • tmaged
                    • Oct 2008
                    • 1896
                    I haven't seen it on the 4 series, but the scanner belt being too tight caused a similar issue on the 2 series.
                    Hope that helps !
                    -Tony
                    www.dtios.com
                    • Scottb
                      • Apr 2013
                      • 308
                      Did you scribe the frame before removing the original lens. I have a habit of this from the Ye Olden days. Mine was a 4 but on the frame it was closer to the 3 mark.
                      • CoreyAbels
                        • Dec 2014
                        • 92
                        In most instances, yes, but in this instance, I did not
                        • CoreyAbels
                          • Dec 2014
                          • 92
                          Finally! Resolution!
                          A little context. Both myself and my coworker put a new ISU (2 total ISUs) in this machine with the same result, a shaded corner on the left side of documents copied from the glass.
                          My coworker and I went back out today and shimmed the ISU with a 1MM washer on the right-front corner (if you are standing at the machine, it would be machine front, right corner) of the ISU to bring the ISU back to level. Testing proved the issue to be resolved. It appears as though there is a bad batch of ISUs out there with warped frames, so be on the lookout!
