Hi Guys, I have a customer with a CS-2553ci, the display is saying replace maint kit A & B, it has 203K on the meter.. I ordered all 4 drum units & wanted to be sure of correct way to initiate these drum units & maint. time.
Question is do I install all 4 drums at the same time, or should I do each one separately & fire machine up, or do them all at one time and then fire machine up?
The manual says to do the following>
After drum replacement, close the cover then turn on machine.
Drum refresh starts automatically.
DO I NEED TO DO EACH ONE OF THESE SIMS ALSO?
Execute the following setting after machine is ready.
• Drum unit initial setting (maintenance mode U119): Execute
• Developer bias adjustment (maintenance mode U140): AC Calib/Calibration
• ID correction operation setting (maintenance mode U464): Calib
• Primary transfer unit initial setting (maintenance mode U469): Manual
THANKS FOR YOUR HELP
