3252ci - "This cassette is printer use only"
  • ThisPete
    Snr/troubleshoot/network
    • Jun 2014
    • 266
    As it says in the title, I've got a Ta3252ci that has suddenly when trying to copy, via the doc feed or glass, started to say "This cassette is printer use only Select another cassette" :
    PXL_20250703_133749450.jpgI can't find anything in the system menu or anything via the web interface, and none of us at work can remember seeing anything along those lines on a Kyocera.
    Minolta/Konica yes..
    Any thoughts anyone?
  • nathicana
    • Aug 2008
    • 335
    The cassette may be set to 12 x 18 paper which is printer only. You can't place an original of that size or enlarge to that size from a smaller original
    • ThisPete
      • Jun 2014
      • 266
      Good thought, but all cassettes are set to their correct 'A' sizes, with settings for plain or high quality.
      • ThisPete
        • Jun 2014
        • 266
        For anyone else in the future, I've just found the answer:
        P.S. please don't tell anyone that I actually RTFM... 😁
        • Dark Helmet
          • May 2009
          • 865
          Why wouldn't this be in the system menu under the paper tray settings. I had a Sharp customer who put color paper in for faxes. You just went to the trays and unchecked printer and copy from those 2 color trays and boom. Fax only trays. Shouldn't require a tech.
          • salvatore
            • Feb 2023
            • 2
            Hi there,
            for the printer only cassette issue. Check your settings in Maintanance mode 341
            • ThisPete
              • Jun 2014
              • 266
              Originally posted by salvatore
              Hi there,
              https://www.copytechnet.com/forum/te...24#post1623224
              • Lunatech
                • Oct 2012
                • 218
                If you haven't had enough coffee you could get stuck in a loop on this one. LOL.
                • ThisPete
                  • Jun 2014
                  • 266
                  ROFLMFAO!!! 🤣
