P3155dn
  • GeorgeBest
    • Jul 2009
    • 525
    P3155dn
    Hi,
    Not much experience on this printer, but
    It gives an error, display indicates: CHECK CASSETTE 1
    I can hear the lift motor moving the paper, but in the end it gives the error.
    changed the cassette, same error
    anyone?
    Thanks in advance
    • 23006
    Re: P3155dn
    Rotate the printer around to the back and peek in the back end of the tray while it's lifting. I think you'll see the tray lift plate is moving in a jerky way because of broken lift drive. =^..^=
    • GeorgeBest
      • Jul 2009
      • 525
      Re: P3155dn
      I looked at the back side when the tray is lifting, but it seems allright, no jerky way, it is lifting normal to the pickup roller. . . .
      • patrickjlc
        • Feb 2015
        • 225
        Re: P3155dn
        Check the little whie flag by the upper feed roller, hanging from the duplex door. Could have come dislodged, just put it back and it should work.
        Sent from my motorola one 5G UW using Tapatalk
          • 23006
          Re: P3155dn
          Also check the paper size switches for proper operation, that the size dial is set correctly. Also there is a place in the system menu to set paper size and type. Are the paper size and type set correctly? =^..^=
          • GeorgeBest
            • Jul 2009
            • 525
            Re: P3155dn
            is in the right place . . .
            • GeorgeBest
              • Jul 2009
              • 525
              Re: P3155dn
              will check that . .
