Kyocera 5053ci f010
  • AiAi
    • Jul 2025
    • 4
    Kyocera 5053ci f010
    Hello
    i have Kyocera 5053ci with broken ssd gives error code f010 , and i have ssd from Kyocera 3252
    HOw to make it work in 5053ci?
    ​​​​Any advice
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1885
    You have to format the hooked up to a PC, deleting the partitions. Formatting it in the machine will not work, as it will not remove all the program info specific to each MFP.
    https://www.copytechnet.com/forum/te...0-error-6053ci
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
    • AiAi
      • Jul 2025
      • 4
      So If i format ssd will work without fw update?
      • tmaged
        • Oct 2008
        • 1885
        I'm pretty sure you'll still need to load firmware as well, since some of it resides on the SSD.
        Hope that helps !
        -Tony
        www.dtios.com
        • AiAi
          • Jul 2025
          • 4
          What if i try to take an image of ssd from another machine will work?
          because I don't have fw
          • Ropariva
            • 673
            This may work for you as previously mentioned, but the hi speed machines used a 8gb ssd and the low speed were 32gb as the hi speed devices also had a HDD for storage. The size difference going from small to large may be overcome by the formatting and reloading of firmware, but it’s not something I’ve ever tried.
            • AiAi
              • Jul 2025
              • 4
              done
              I got ssd from 4007 and machine working well now
              thanks to you all
