whats happening is this machine gets paper wrapped around the fuser .and then throws this code. ive replaced the high voltage plate on the conveying unit and the corresponding springs on the registration assy, when it was doing this and making black skyshot arc bands on the copy. after the replaced parts the arc banding went away, but im still left with the occasional fuser wrap.
Although I havent yet my next set is to check wall voltage, unless someone here has seen this and knows the fix.
