Copystar 3050ci IH fan motor C-6940 code
Re: Copystar 3050ci IH fan motor C-6940 code
Yeah, I think I'd clean out that squirrel cage first. It's located on the right side, in the rear column behind the door. You'll have to remove the fuser and some covers to see the fan. The good news is that you probably won't need to remove or replace the fan. Just take a spring hook and pick out the giant ball of fuzz obstructing air passage.
This photo is from an Alphard I Zeus, not an Alphard I Venus, but the effect is the same:
=^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^= -
What Blackcat said. I've never had to replace one, only clean them out. There's a bulletin for a filter that sticks on the outside, to keep you from having to tear it apart to clean it.Comment
[ATTACH=CONFIG]52975[/ATTACH][ATTACH=CONFIG]52974[/ATTACH]
=^..^=Comment
That's correct. Depending on the environment, you may also remove the metal cover over the IH PWB and blow it off. Sometimes the heat sinks will get buildup on them also, not allowing for proper cooling.Comment
Once again thanks for all your help !Comment
No, not the fuser fan.
#20 in this illustration:
IH Fan #20.jpg =^..^=If you'd like a serious answer to your request:
It looks like 302K994360 to me also. Not sure why it says that unless it's used in both places.
The add on filter is 302N494240.Comment
Here:
Most of the time the fan just needs cleaning. I have replaced this fan on a couple of Zeus, but it did not solve the issue. I have replaced one or two IH boards over the years. =^..^=If you'd like a serious answer to your request:
Thanks for all the help, I really appreciate it!
I got over there today and not much fuzz in the fan but it was to the point of being locked up so had to order it That is one PITA getting to it and replacing it but I could have never found it without the help, thanks again !Comment
