TAskafa 5501 , paper jam at ADF
  • Gab
    • Aug 2015
    • 671
    JAm code 9011 and 9005. It looks like it tries to pull the paper but it doesn't . No obstacle.
    Any idea?
    • 23009
    Re: TAskafa 5501 , paper jam at ADF
    Did you looked up jam 9011? =^..^=
    • JR2ALTA
      • Feb 2010
      • 2033
      Clutches and sensors are really solid on this adf. Have you tried cleaning or replacing rollers/belt?
      • avio2
        • Jul 2010
        • 150
        so it's hard to help you, what tests have you done? from memory, for example, the rear pin of the document lifting plate may be broken
        • Tonerkiller
          • Oct 2012
          • 668
          Possible sep arbor issue?
            • 16416
            What model ADF? I've had problems with the one-way bearing in the gear pack. If you put a little pressure on the roller with your finger, it will stop turning. A sure sign that the bearing is slipping. Good luck.
            • spw
              • Mar 2015
              • 62
              The simplest ones for hesi pulls are like what was mentioned dirty/slipping pickup rollers ( the turtle shell looking ones) on the upper or the belt. If not those 2 then the 3rd option for hesitation is checking the torque limiter for a crack in it. Its under the black plate(2 screws) inside the yellow/green/grey whichever color sep roller your using. It just slides right in. They break all the time.
