cyan problem TASKalfa 2353ci
  • dikyo
    • Apr 2011
    • 45
    Hi Guys,
    I have a problem with cyan on this machine.
    (see attach.)
    I already replaced:
    all developer and drum units
    Main high voltage pwb
    Parts pwb Drum Dlp connect
    Feed Image pwb
    Engine pwb
    Problem is not solved yet.
    Any suggestion is welcome
    Thanks in advance
    Grtz
    Dikyo
    • 23009
    Re: cyan problem TASKalfa 2353ci
    Do you see this pattern on the developing roller? Are you using genuine toner? =^..^=
    • avio2
      • Jul 2010
      • 150
      Originally posted by dikyo
      Hi Guys,
      (see attach.)
      I already replaced:
      Feed Image pwb
      Engine pwb
      Thanks in advance
      Grtz
      Dikyo
      dv unit is news?
      before change dv and dk have turno off and disconect ac cable?
      • sparkycivic
        • Apr 2017
        • 348
        I'm going to throw out a guess of: LSU. Only because I cannot imagine how a mechanical issue can do this since so many parts have already been replaced.
        This unit uses a LSU with four lasers, and a common polygon motor, so perhaps the cyan laser is somehow malfunctioning? Also there is no feedback inside the LSU for verifying color laser operation, only black so cmy laser malfunction will not result in any failure code except for calibration fail C76XX.
        I also notice that the area which SHOULD be cyan, is not, but instead continues the background pattern.
        • toddanderson
          • Dec 2005
          • 236
          Run a copy with the cyan main charge roller removed and post the sample.
          • dikyo
            • Apr 2011
            • 45
            Hi ,
            Thanks for so far.
            This pattern is also visible on the drum.
            Off course we use original toner.
            When i am back at the customer I'll post some examples.
            grtz
            Dikyo
            • pascalb.
              • Aug 2016
              • 47
              Hello,
              Personally I think a cyan bias problem.
              have you checked the high voltage?
              Do not lament,
              do not mock,
              do not hate,
              but understand.
              • dikyo
                • Apr 2011
                • 45
                Hi Guys,
                After replacing the Main highvoltage pwb for the second time the problem was solved.
                grtz
                Dikyo
