6002i poor image on status page
  • buzz
    • Aug 2013
    • 288
    Changed drum and dev and performed all adjustments.
    Now image looks like this:
  • JR2ALTA
    • Feb 2010
    • 2033
    Re: 6002i poor image on status page
    What did it look like when you put the old drum and dev back in? That would be my first instinct.
    • mntech
      • Aug 2010
      • 250
      It looks grainy like it's pulling developer on to the page, does it feel grainy? Check to make sure the drum charge roller holders didn't break during shipping. I don't remember, but does that dev unit have the small clear mylar with rubber against the mag roller that is supposed to be removed? I've forgotten to take one off before and had similar results
      • buzz
        • Aug 2013
        • 288
        I did a half stop and found the same pattern on the developer
        mag roller. I'm suspecting the developer is defective. I did make sure the little packing spacers were removed too (thanks mntech good call, I forgot these as well before).
        I did not want to put the old DV back in as that one was pouring out a leak that got all over the LSU and cassettes which took me a while to clean out. Anyway, will be back with another DV and see. Will post results. Fortunately they have another copier onsite to use. Thx so much!
        • spw
          • Mar 2015
          • 62
          looks like a toner spill inside the machine thats getting picked up and smeared. Id check the charge roller for any residue in the same pattern as whats on the page
          • rapo_tech
            • Feb 2019
            • 114
            You are saying that spilled toner gets on DEV mag roller?
            If the charge roller is dirty it would repeat the pattern through the page... As you can see on the sample, there is no repetitive fault.
            It is 95% bad developer unit.
            • KYO_OEM
              • Aug 2011
              • 721
              have seen exactly the same printouts like yours.
              Reason:
              Tech didn`t unplugged the power cord from the wall outlet.
              Now wrong counters for DK and/ or DV and system is creating wrong voltages.
              I checked needed time for 1 page and get this result: 3011 sec/ page. (U157*60sec=needed developing time/ page)
              Take a look for U110, U117, U118, U120, U930, U157, U158, U984 and U985
              • buzz
                • Aug 2013
                • 288
                Reason:
                Yes, this is exactly the same kind of sample print out. It was me who installed both drum and dv. And from previous experiences I made sure machine was powered down properly and unplugged when replaced. I was also in the process of running the set up modes of u119 u464 u412 u469 when I discovered the test chart being distorted.
                Thanks so much for posting the same sample issue. I will check these values.
                So your fix was u157 needing to be at 60sec? I'll check that as well.
                How do I get it to normal values if it's off?
                • KYO_OEM
                  • Aug 2011
                  • 721
                  No way out without new parts.
                  Wrong values on Eeproms from DK or DV you can`t restore or change.
                  Maybe U100/ Set DC Auto Adj change from "ON" to "OFF" can be helpfull until you are able to assemble new DV and/ or DK.
                  Also take a look for Eventlog
                  Maybe hidden C7200 or C7241 visible.
                  During analysing from reports, this shows me that tech. didn`t unplug power plug before disassembling..
                    • 16416
                    This is exactly the reason that it's standard operating procedure for me to unplug the mahince any time I put a screwdriver to it. Better safe than sorry and forgetting to unplug the machine could be a costly mistake.
                      • 900
                      So just turning the main switch of would not prevent this .
                        • 23009
                        Is this resolved buzz? New drum & developer again? =^..^=
                        • buzz
                          • Aug 2013
                          • 288
                          We received the part and finally got back out with a brand new DV unit and that did the trick.
                          Copies are superb again, thank you everyone!!!
