3252ci colorful streaks
  • buzz
    • Aug 2013
    • 288
    2 new Transfer belts TR8550 are doing this.
    When I put the old one back in it goes way.
    Drums and dvs we're recently replaced too.
    OEM toner.
    Edited post:
    Seems like lines only appear and stays on the belt where it doesn't clean off during a calibration (U464, U469...)
    Otherwise copies and print jobs are pristine and clear from streaks: see here
    Screenshot_20220616-182023_Adobe Acrobat.jpgScreenshot_20220616-182026_Adobe Acrobat.jpgScreenshot_20220616-182019_Adobe Acrobat.jpgScreenshot_20220616-182015_Adobe Acrobat.jpgScreenshot_20220616-182010_Adobe Acrobat.jpg
  • Horologydoc
    • Jun 2011
    • 61
    Re: 3252ci colorful streaks
    I've seen this issue where one of the pins on the transfer belt harness was bent and not making connection to supply power to the transfer cleaning motor. The machine didn't throw a 1950 or any codes. Check your pins where you plug the transfer belt in. I've also had to put some cardboard behind the connector on the belt itself to push it far enough forward to make good connection.
    • KYO_OEM
      • Aug 2011
      • 709
      Please take care for enclosed check points
        • 22999
        Thanks Kyo. I've seen these particular marks when I've had a Hanabi primary transfer belt unit apart, and I forgot that spring at the front left ... that provides a bias voltage for the cleaning roller.
        "I wonder where this spring goes ... ? I'm thinking it's important ... " =^..^=
        • buzz
          • Aug 2013
          • 288
          Blackcat where is this spring located? Front edge of transfer belt? Sry I'm not in front of one at the moment
            • 22999
            On Hanabi KM-2550ci transfer belt unit it's on the front left. I can't say if that same layout is used on the Iris2.
