Taskalfa 2554ci Scanning pause before can touch start button.
  • dalewb74
    • Feb 2018
    • 1153
    #16
    Re: Taskalfa 2554ci Scanning pause before can touch start button.
    yes you can pre-program buttons for scanning. but i think it is only an option on the desktop versions.
    • Ropariva
      • 676
      #17
      Originally posted by AGI
      We have a customer who we upgraded from a 2 series to a 4 series. They are pissed because of this issue. The want us to take the MFP out.
      Have had the same. Please put pressure on your Kyocera support to have this changed. The more pressure worldwide the sooner they will take notice. We have sent several pleading emails regarding this and have so far managed to avoid swapping machines back out. The best you can do for now is to revert to ver 2.08firmware
      Hopefully they will resolve this soon.
      • Konicatech
        • Feb 2016
        • 131
        #18
        Upgrade firmware to latest version... the option to turn off the address check option is now available
        • Samanator
          • Sep 2017
          • 579
          #19
          To be clear, the latest firmware to get would be version 3.07.
          Is this also true with 3554ci thru 7054ci & 4004i thru 7004i? The latest firmware for those models is version 3.07 as well.
          Is this the way to turn off that annoying sales killing feature:
          Function Settings > Prevent Miss-Sending Settings > Turn off the following: Destination Check Before Send & Entry Check for New Dest.
          If the above is correct, I will have everyone update the firmware and turn off the annoying features as we encounter these models currently out in the field.
          I just set up a 2554ci last week. I do believe that during a new machine setup that this comes up as an option to set.
          • Konicatech
            • Feb 2016
            • 131
            #20
            Hi
            Yes you are correct, latest firmware and then make those changes.
            • Samanator
              • Sep 2017
              • 579
              #21
              Curious that Kyocera doesn't mention this change in the Firmware Release Notes.
              .....just sayin'
              • Ropariva
                • 676
                #22
                • marley
                  • Sep 2010
                  • 58
                  #23
                  .."Upgrade firmware to latest version... the option to turn off the address check option is now available"
                  I ran ... but the problem remains!
                  • Ropariva
                    • 676
                    #24
                    Really? That makes me very sad [emoji22]
                    • marley
                      • Sep 2010
                      • 58
                      #25
                      I confirm that the problem remains!
                      • Ropariva
                        • 676
                        #26
                        Anyone else updated to package 3.07? Can you confirm if this actually allows the pop up to be removed?
                        Thanks.
                        • Samanator
                          • Sep 2017
                          • 579
                          #27
                          Works for me.
                          • marley
                            • Sep 2010
                            • 58
                            #28
                            has anyone tried?
                            Thank you
                            • Samanator
                              • Sep 2017
                              • 579
                              #29
                              I have installed the latest firmware, v3.07, and the ability to turn off Address Check option is there as explained earlier in this string.
                              I have done this update and change to some older models I have out in the field. Specify a 2554ci, a 4054ci, four 3554ci, and a 6004i. In each case I was able to turn off Address Check option.
                              Also on a new out of the box 2554ci and a 5054ci. Updated the firmware and I was able to turn off Address Check option on both machines.
                              • seeya-zn
                                • Jun 2020
                                • 10
                                #30
                                I updated the firmware on a 4054ci to V3.07 and the confirmation message still pops up when you select a one touch destination. I had to roll it back the firmware to V2.04 .
