CS-2553ci broken paper feed lift gears...
  • Oystercopy
    • Oct 2009
    • 623
    Hey guys.. I have a customer who set one of these up themselves, and did not remove the tray locking bracket on the top tray, then powered it on.
    My suspicion is that it broke the lift gears in the rear, but I had a heck of a time even getting the back cover off to look it. Well, they want me to fix it, so I wondered if any of you were ever back there and had to do anything on this model?
    Of if you might have had the paper feed lift assembly out before to do any work to it?
    Thanks in advance.
    OC
  • PrintWhisperer
    • Feb 2018
    • 473
    Re: CS-2553ci broken paper feed lift gears...
    They will bind up but generally they don't break. The coupler is spring loaded, remove the lower tray and reach in under and try to push the coupler away from the cassette (rearward). Worst case loosen the lift motor assembly (rear).
    Probably needs a 906 reset.
    "Being ignorant is not so much a shame, as being unwilling to learn" - Benjamin Franklin
    • Oystercopy
      • Oct 2009
      • 623
      Thanks for that PW, but I thought I heard the motor running when powered up... then again, I could have been hearing the other motor for the lower tray run, for all I know. I took the lower tray out, but I guess the motors might
      run either way, not knowing if there's paper there until they start to lift and don't see paper?
      I just got the assembly apart (luckily, it came out from the front) but can't find any broken or damaged gearing. So, as a precaution, I'm just going to order all the gears and motor and then go back out there.
      I didn't know that there was a "reset" code for this issue... can you tell me how I can get into service mode to clear it?
      OC
      • copykat93
        • Oct 2021
        • 281
        If you're not getting an error code on the display, then it never threw a code, especially if you heard the lift motor running. If the motor throws a code, it will disable that specific drawer & show on the display. If there is an error on the display, check your messages & I will send you the sim & procedure to reset the inop message.
        • Oystercopy
          • Oct 2009
          • 623
          I never saw an actual "error" code; only that the Tray was out of order.... And again, I'm not sure which motor I heard running, or if they'll run each time the machine is rebooted (regardless).
          But since I didn't find any broken gears, I'm assuming that maybe there's a "condition" that needs to be cleared, so YES, please send me that procedure, Copykat!
          OC
          • ntbann
            • Jan 2012
            • 628
            Print Wisperer told you how to reset it. Run a 906.
            • dalewb74
              • Feb 2018
              • 1157
              if you don't know how to get into service mode you should call a kyocera tech.. that isn't something that should be posted here.
              • copykat93
                • Oct 2021
                • 281
                Originally posted by oystercopy
                i never saw an actual "error" code; only that the tray was out of order.... And again, i'm not sure which motor i heard running, or if they'll run each time the machine is rebooted (regardless).
                But since i didn't find any broken gears, i'm assuming that maybe there's a "condition" that needs to be cleared, so yes, please send me that procedure, copykat!
                Oc
                check your notification box, i sent the entire page of the process to reset the drawer error... I CLICKED ON YOUR SCREEN NAME & SENT YOU A PRIVATE MESSAGE WITH THE DETAILS
                • Oystercopy
                  • Oct 2009
                  • 623
                  You REALLY should know when you're talking to another tech or an end-user. I'm the former, with over 44 years of experience.
                  Just because someone doesn't have (what you consider to be) the proper knowledge on that
                  product, you can still tell when they don't know what they're talking about in this industry. I've known (and worked with) plenty of "trained" technicians who
                  couldn't find their ass with both hands. So there's that.
                  OC
                  • copykat93
                    • Oct 2021
                    • 281
                    OC
                    AMEN BROTHER... I am always happy to help.. Lets not discourage each other from helping, I love this site & truly appreciate all the help & the opportunity to help others. Lets keep this in a positive light
                    • Larhal
                      • 584
                      Once Again you like to belittle Techs on the site without really looking in to the situation. If you cant contribute with positive, don't contribute at all.. Give it up looser.
                      Larhal
                      If all else fails read the Service Manual!
                      If that fails, meet me at the pub and we will discuss it.
                      • Oystercopy
                        • Oct 2009
                        • 623
                        Thank you SO MUCH Copykat... I went out to the machine today, and although it was a little tricky (or so I thought) getting into simulations, I was able to get the machine FIXED... thank you again sir!
                        OC
                        • Larhal
                          • 584
                          I also have a unit that has locked out a paper drawer. Changed the motor with a known good one, was not the problem. Changed the paper drawer with a know good one , not the problem. I looked in the service menu and found the 906, did the reset, cycled the machine and all is good now. Thank you for your information. Success
                          Larhal
