Kyocera 6002i black streaks
  • copyaction
    • Oct 2007
    • 991
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1888
    Re: Kyocera 6002i black streaks
    Looks to me like something is in the drum seal/blade area causing toner to drop. Could also be primary belt cleaning, but that's not a normal defect.
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
    • KYO_OEM
      • Aug 2011
      • 721
      problem visible in margin areas --> charge related
      Remove MC, disassemble cleaning blade, check for foreign objects at first
      Hopefully no blocked waste forwarding to waste drive unit
      In case of waste blocking, follow up tmaged and check waste drive from belt also.
      • copyaction
        • Oct 2007
        • 991
        That sounds like trouble.
        • sparkycivic
          • Apr 2017
          • 348
          the developer is likely puking toner, which has been an issue for that model in the early days. it will be instantly obvious upon visual inspection of the developer unit.
          • copyaction
            • Oct 2007
            • 991
            I went ahead and replaced the maintenance kit.
            Everything looks good but they did say it was happening intermittently so we will see.
