[HELP] KYOCERA M2540dn
  • sinner231_100
    • Aug 2022
    • 6
    Good day, may I just want to ask for a help, is there anyone experience this kind of error. There is a blurred print out on my machine on the left side. I attached a copy of output.
    we already tried to clean to waste toner container, and other parts, but still the problem exist. Any help will be highly appreciated. Thank you..
  • copiertec
    • Jan 2016
    • 2184
    Re: [HELP] KYOCERA M2540dn
    Replace the maintenance kit.
    • Synthohol
      Certified Konica Expert
      • Mar 2016
      • 5735
      Maybe clean the laser?
      BTW, why would cleaning the waste toner help with fade?
      That's like your car won't start but you checked the tire pressure.
      • JR2ALTA
        • Feb 2010
        • 2028
        no offense, but given your location I can guarantee generic toner, so all bets are off.
        • sinner231_100
          • Aug 2022
          • 6
          You mean the whole maintenance kit?
          MK-1158?
          • sinner231_100
            • Aug 2022
            • 6
            Laser on the glass? even on the upper feeder is still faded...
            • sinner231_100
              • Aug 2022
              • 6
              we are using a genuine toner.. from philcopy..
              • Synthohol
                • Mar 2016
                • 5735
                explain, i dont understand.
                the pics you posted are a copy or a print?
                • sinner231_100
                  • Aug 2022
                  • 6
                  copy sir, but if im going to print Status Page, the print out is good, no faded parts...
                    • 22927
                    Have you cleaned the scanner optics?
                    • sinner231_100
                      • Aug 2022
                      • 6
                      im sorry for being noob, can you tell me what particular parts on the picture should i clean..
                      • dalewb74
                        • Feb 2018
                        • 1117
                        [ATTACH=CONFIG]54485[/ATTACH]
                        being that you are a noob, as you stated. your best bet is to call a trained tech. if you don't know what you are doing in that area. you could really mess some stuff up. and basically brick the machine.
                          • 22927
                          Cleaning scanner optics on small tabletop MFP's can be a major operation, usually involving removing the DF & the whole scanner assembly, then flipping the scanner assembly upside-down to get to the screws. And there's plenty of opportunities to mess up delicate components.
                          An experienced tech can get those optics clean in an hour ... and the machine will still work when it's clean. That's my recommendation. =^..^=
