COPYING TIMING TOO LONG
  • JINACHANDRANS
    • Sep 2019
    • 41
    Hi friends, kyocera taskalfa 1800 copying time is too lone while copying in multiple copies.(i.e while taking 10 copies in same matter first 2 copies are coming normal then machine runs for 10 to 15 seconds then another 2 or 3 copies coming out then the same delay process is repets) i changed thermister and fuser roller too but the same problum presist.
    • 23003
    Re: COPYING TIMING TOO LONG
    Perhaps the toner level is getting low, and it goes into a toner add cycle. Does it display: "adding toner"?
    • Samanator
      • Sep 2017
      • 577
      Just to be sure, when you say copying, is that to set a document on the glass or in the ADF and make a copy, or you printing something to the machine via a computer?
      • JINACHANDRANS
        • Sep 2019
        • 41
        i make the copies with orginel documents placeed in glass. its not printouts from computer.
        • JINACHANDRANS
          • Sep 2019
          • 41
          is it require any firmware update?
          • copykat93
            • Oct 2021
            • 273
            Are you using OEM Kyocera toner or aftermarket compatible?
            • justanotherhack
              • Apr 2015
              • 74
              Have you checked to see that all of the paper trays are behaving this way (run something through the MP tray to compare)? Feed rollers may be worn out, separation pulley has flat spots.
