M2540 series fuser problem
  • campy
    • May 2012
    • 315
    Anyone having problems with the fuser film not rotating and causing the paper to stall going through. I have had at least 3 and 2 of them have been the same machine. I replace it and it works fine for months.
  • kuby
    • Oct 2007
    • 1400
    Re: M2540 series fuser problem
    Try stretching the spring in the fuser drive assy. Worked for me. After a while it gets week and will and turn the fuser, a new fuser will work for a while and then it starts jamming again.
    • campy
      • May 2012
      • 315
      How does that slow the fuser without making a gear noise?
        • 23007
        There must be a dozen threads about the teflon sheet drying out on these fusers, slowing the fuser drive. They never make yield.
        • tsbservice
          Field tech
          • 8009
          Assuming it is like Brother MFPs you can disassemble fuser and wipe out old grease clean everything and put new grease. Job done for a moment. If teflon sleeve is worn out that is another story.
          • kuby
            • Oct 2007
            • 1400
            Sorry wrong post
            • campy
              • May 2012
              • 315
              I followed this video and after running about 50-60 copies it seems to work. I couldn't get 1 copy before. I will test some more. I used a high temp grease that I use on Canon and HP.
              Kyocera P2235dn, M2040dn fuser repair. - YouTube
              • ntbann
                • Jan 2012
                • 628
                This works for a short time but will fail again. A new fuser, update the firmware, and make sure the sleep timers aren't extended way out works the best.
                • kuby
                  • Oct 2007
                  • 1400
                  Yes the sleep timers get reset by the customer. Need to check them.
                  • rapo_tech
                    • Feb 2019
                    • 114
                    Tried the same way...
                    I had problem when printing in morning, first print was still smeared.
                    Dissassembled again, cleaned and used grease with few drops of silicon oil.
                    So far (5000-6000pages) it is working fine.
                    Anyway new fuser and "silent mode" works best. Even the client is happy when i tell them that i made printer quieter
                    • gregrcs
                      • 22
                      This style fuser has a lubricating cloth inside the fuser sleeve that tends to bunch up and cause drag on the sleeve. Your best bet is to replace it or replace the fuser.
