408ci Scan Extension kit (A) questions
  • copydocinc
    • Mar 2015
    • 263
    Does anyone here have experience with this scan extension kit?
    How and where do I install it and what else is required.
    I read that it requires a memory card and possibly firmware reinstalled.
    I have installed many Kyocera machines, but never this kit.
    Any tips and info would be greatly appreciated.
    Oh and I also read that it is meant for A3 machines, but it in the 408ci optional accessories list
    Will it work in the 408ci?
    • 23010
    Re: 408ci Scan Extension kit (A) questions
    According to the Kyocera website it is compatible with your KM-408ci. I have not installed one of these kits, but I suspect that it is a license add-on to allow optional OCR when scanning.
    • tmaged
      Owner/Service Manager
      • Oct 2008
      • 1897
      The 408ci has a SSD & HDD so there's no need for storage. You only need to add storage on the 308ci.
      I believe you can do a couple of 30 day trials on it. It should be in the system menu under System/Network>options.
      Hope that helps !
      -Tony
      www.dtios.com
      Become a fan on Facebook
